OBD-0 B18a swap Help
So I just swapped my B18a swap into my CRX HF and it's throwing a code 14 and 15...Idle Air Control and Ignition Output Signal. So I swapped out the IACV and replaced the distributor. The code 14 went away but it's still showing the code 15, Ignition Output Signal, and called King Motorsport...they suggested the distributor was bad, had it tested...and it's fine. Any ideas? I may just re-run the harness or purchase a different/better one and see if that does the trick. Please help my build!
