Broken timing belt
this is urgent if someone can call me to help me figure this out it would be appreciated..i just was trying ot get to my grandmas house going through a bunch of snow and i was having to rev high in 2 low gear and car just turned off..opened hte hood and the belt was snapped. if you can call me at 616-485-3813 need help with this asap. not sure which one it is but its the one thats directly connected to the engine please help
4wd?
2wd?
Different motors=different things to worry about
OR you can look at the plus side and say "hello new motor"
I pretty much knew right away what the problem was, but that didn't stop me from trying to start it a couple times. I had the car towed home, threw on a new belt in about an hour, and was back on the road, totally unscathed, except for the lost revenue from being off the road for 2 hours. I was courier driving at the time.
All this to say throw on a new belt and try it. I'm willing to bet you're gonna be fine.
I knew the dual points were. That's what I was getting to above.
I think a well maintained 20yr old civic is very reliable, I wouldn't trade any of mine for a new car.
Jaker was lucky.Hope it's not bent.If it's bent a little bit.You'll just loose some mpg & a wee bit power.I bent a valve on a '84 & lost 2-3 mpg.
It's not a huge big deal to run without it. I've run all my cars without them for the last 20+ years, both in Eastern Canadian weather (think northern Michigan winters) as well as here on the wet coast. The only issue I ever had was finding a small sharp stone poking through the timing belt on Saturday before a Sunday autocross. Since there were no belt covers on the car, it literally took me 45 minutes to change the belt.
I'm glad to hear things worked out. I guess that's 2 of us that have been "lucky"!
