Post your B-series
wagonef8
Wagonist
it will be almost a year since i got my WAGON and almost two months since I swaped it and would like to read more stories of what other people went through while doing their swaps and pictures of how it turned out and advise you want to share for others wanting to do a swap
never inteded for my wagon but wanting to be diferent I pulled the swap out of my rex and put it in my wagon insted of my D16z6 wiring was easy had already done a multi point conversion for the Z6 and only had to shorten my crx shift linkage a few inches hasport motor mounts and DA axles obd0 to obd1 jumper and Neptune P72 ecu
b18c1
b18c1
Specs: B18A1 with lightweight flywheel, 6 puck clutch, innovative mounts and linkage.
empty bay
donor B18A1 and cable trans
All in
JDMWago666 hey Pm me I can help you with wiring
Anywho here's mine:
OBD1 JDM B18c (non Type R) with S1 Cable gearbox, DA6 Axles, Custom engine loom and Innovative mounts:
n00b
Actually, it could be in general too maybe. If he just wanted pics of B-series, I would have left it. It was the shared experiences reason for moving.
Hopefully I'll have a B before the end if the year. Too many projects in my life. Wish I could just work on my damn car.
It's fine here, I think it will also give newbies an idea of what's possible or been done.
The GSR that is in my Wagon right now.
But it is coming out for an LS-V as soon as i get the time and place to do it.
