Were is neutral on 4wd tranny
I'm putting my wagon back together. How do I set the gear selector on top of trans to neutal???
  • One of the levers will naturally default to the neutral position, and the other one has 3 position, and the middle one is neutral. Why?
  • SONY4059SONY4059 Band Wagon
    Ok. Had a problem, after swapping motor. The car wouldn't move. Couldn't feel any gears for inside the car. Wasn't sure what position the lever was in before. I'm trying to finish up asap, if I get some good weather by me...
  • klumklum Senior Wagonist
    it doesnt matter what position the levers are in i had the same thought cross my mind just connect the linkage and it will be fine!
  • bucky4ubucky4u Band Wagon
    ya ' like he said ^ the selector wont effect anything ' shift linkage would b the key!
    Well, finally got a chance to go online. Everything went back on good. Car moves. Only one more thing, since connecting the cables the shifter feels mad tight. Hard to find the gears.
  • zaccivic90zaccivic90 Band Wagon
    pick says it all put it in N
