Anyone running a brake booster delete?
is anyone here using one on there wagon?
i have seen a few hondas on h-t running them ill get a pic for you guys.
not my pic's i got them from honda-tech
the one for 135 is from here www.kenskustomchassis.com according to the h-t build i was reading
I am able to safely drive the car on the road. Yes, the pedal is much more firm than the OEM setup with the booster, but that does not prevent me from stopping properly in an emergency situation. I "needed" to remove the booster for clearance reasons with my powertrain.
If I get a chance, I'll post a couple pictures of the setup.
I'm just curious why making it harder to brake is a good thing. Does it increase pedal feel massively? Can you feel your brakes overheating or something?
Aswell as having to apply more pedal effort to brake, being a single diaphram setup, it means that the brakes would have to rely on one diaphram to feed pressure to both front and rear brakes.
Imagine if this brake master cylinder gave up or had a fault. It would mean that you will lose all brakes to front and rear at one time! Whereas the OEM cylinder is a tandem setup, where if e.g the front brakes fail, the rear will still have brake effort.
wouldn't be the safest mod, but i must admit, it does tidy up the engine bay somewhat!
