RT4WD auto, slow into reverse?
The thread on grinding in reverse inspired me to ask about this little quirk. Ever since I got it, sometimes - not always - when the temperature outside is cold, my car takes several seconds to actually engage reverse from the time I move the shift lever into R. It always goes eventually. It doesn't do this at all in warm weather. Fluid level doesn't matter - it's been low before (small leak in the tranny), but does it when full too. I replaced the fluid when I replaced an axle a month or two ago, and that hasn't had any effect (though the fluid is much cleaner now, old stuff wasn't).
Anybody know why it may be doing this, and/or how to fix it? Other than not back up or drive when it's cold...
is set (adjustable) at rotational speed/ratio(s)
if its to low it just wont pick up...
my english technical jabbaryahoo sux ...
so whats the problem then...
similar mishaps could derive from the smallest things ...
before i get lost in techlingo ... it could be electronical too ...
a lot of things start to happen when your battery is on its way ...
mind the quotes
RT4wd 89
Trans was rebuilt on Mar, 2010
Is it problem on trans again? or just due to cold weather, or is it normal reaction?
Anybody help?
any ideas?
Is it normal or something wrong on trans?
Thanks
Have you ever tried to shift it from D to N (pause .5 sec) to R in step slowly? Is it still slow to engage on your wagon? I am wondering if others have similar reaction.
Why is something spining although I stepped a brake?
Any help?
Bad ATF?
Thanks
