CEL comes on while cruising at HWY Speeds
So here's my problem...after running for about 5 min. and hopping onto the nearest highway the check engine light decides to turn on. I usually cruise around 70-74mph
a little fast...but never had a problem untill today. When I finally arrived at my destination I shut off the car, let stand for a minute, then turned it over and no CEL. So I thought it was fine, untill it did the same thing to me on my return trip. Got home and turned off, then on...and no CEL.
Has anyone had this happen to them or something similar so that I can figure out a possible problem and solution.
Speedo seems to be accurate. Maybe I'll switch the o2 sensor just to be safe.
1= O2 sensor, simple fix.
