Fuel pump won't prime
US 90 civic wagon dx d15b1 automatic fwd urban brown
i cant figure out why the fuel pump will not prime when the car turns on. i tried running a 12v wire staright to the pump and it primes. pump works and from what i can see, the wires are in operating condition. besides the main realy, which has been changed, what could cause this? ecu? another relay?
any help will be welcomed.
thank you in advance.
EDIT: The fuel pump runs off #14 fuse, not sure about the main relay.
Check you have voltage at the pump when you turn the key and go from there
sorry it took so long to respond. thank you for responding as you did.
the clock for some reason isnt working either.
thanks chadwick
viewtopic.php?f=5&t=7134
