Starting problem
my car is having some problem starting, when i turn the key the starter just clicks, but if i turn it a good 10-50 times and it eventually works. i tested the whole starter/alternator system and everything comes up clear. has anyone else had and solved this problem or have an idea what it could be? i'm about to just replace the starter and cross my fingers.
I havnt pulled apart a Honda starter but changed them on my parents Hilux and it was easy as, new contacts were like $12
It's either a starter problem (you can rebuild it yourself if you know how, or buy a new one) or a bad ground or the ignition switch is going bad.
Also, it could be a faulty neutral safety switch. Make sure you have the clutch pedal all the way down. Check to make sure the rubber plug on the clutch pedal arm is pushing the end of the switch when you push the pedal down. Those rubber plugs deteriorate and fall out over time. You can buy a new one or super glue a penny in its place. If it does start eventually, then the plug is probably not missing though. Switch could also need adjusting.
Let us know if you get it figured out.
Swivel adapter, 2 6" extensions, and a lot of patience.
Can someone explain this safety switch to me? I am having this same problem, and yesterday, something fell out from above the pedals, Thank you
Ok basically, there is a switch mounted up behind the clutch pedal, and when you press the clutch pedal all the way in, it presses on the switch, completing the circuit to the starter. It's designed so that you can't turn the key without pressing the clutch in, as a safety measure to make sure you don't start the car with the transmission engaged and end up driving away unintentionally.
What most likely fell out was the actual rubber plug that pushes the switch. The switch isn't activated by the pedal itself, but a small rubber plug that fits into a hole in the pedal arm. When these plugs deteriorate, they fall out, leaving just the hole, which obviously won't push the switch. They use the same type of setup for the brake light switch, and the cutoff switches for the cruise control. I have had these plugs fall out on several of my hondas.
I'm sure the plugs are fairly cheap from the dealership, but I've never bought them. I usually super glue a penny over the hole. The switch is adjustable in case it's too far from the penny.
Thank you so much! That's exactly what I was talking about.
Can you take a picture of where this goes, cause I'm kind of a big guy :roll: so it's hard to weasel down there with a flashlight and get a good look.
Thanks in advance!
If you look up at your clutch pedal of the pedal assembly you'll see a cylindrical plug and the plug in itself is yellow.
If you trace that back up toward the rear of your clutch assembly you'll feel the switch that needs to be pushed down.
As you keep your hand there and push the clutch down with your hand you can feel where the pad should be and has worn down.
For an easy trouble shooting way to find out if thats exactly it, just push down the sensor button and try and start your car.
Mine fired right up and i just need to find something to replace that pad on my clutch pedal.
If you were to just somehow keep that sensor pushed it could that potentially drain the battery?
I wouldn't think so but you never know, more for knowledge then actual being put to use.
I'll explain the glue/penny method of replacing a worn plug.
BE VERY CAREFUL! IT IS TOTALLY POSSIBLE AND EVEN HIGHLY LIKELY THAT YOU WILL SUPER GLUE YOUR FINGERS TO THE PEDAL ASSEMBLY!!!! Keep a bottle of nail polish remover handy, it will break down the glue if you get stuck. Also lay an old towel on the floorboard so you don't spill remover on your carpet if you need to use it.
First, remove any pieces of the old broken or worn out plug.
Test fit the penny to make sure you can actually reach the hole. You may have to try a few times from different angles, and it will be a pain in the ass. But it will help you figure out the easiest method BEFORE you get glue all over the place.
Next, you have to get the penny glued over the hole. This is the hard part, because its REALLY hard to reach it. I figured out a risky but effective method of getting the penny up there without dropping it. drop a tiny little dab of glue on the heads side of the penny. Not a lot at all, just enough to fuse the penny temporarily to your finger. It should be fairly easy to pull your thumb off the penny.
Lightly cover the entire tails side of the penny with super glue. This side will attach to the pedal, over the hole, and push the switch. Reach up there and hold the penny against the pedal, long enough for the glue to harden. After about 15 to 30 seconds, wiggle your finger around a little (yeah!) to make sure its nice and solid. When you're sure the penny isn't going anywhere, gently pull your finger off the penny. As long as you didn't use too much glue, it should come right off. It helps to roll your finger back and forth to help peel it off.
Rinse your finger off with the nail polish remover to get the glue residue off, or just wait a day or two for it to fall off, and you're done!
