Looking to raise my wagon
hello, I recently acquired a fwd 1990 civic wagon in decent shape, but it's been lowered and I really don't care for it. I've looked for a set of stock springs but parts are hard to come by for these little cars. My question was, will stock springs from an ef hatch or sedan work? If not what are some other options?
  • Dash-N-CarsDash-N-Cars Senior Wagonist
    I have a set of stock wagon springs, from a 91 FWD. I'd sell them to you just make me an offer.
  • Ajr49123Ajr49123 Band Wagon
    Just the springs?
    Yeah just the springs.
    Yeah I have completely aftermarket shocks. I was looking for 4 stock shocks, or could I put stock ef hatch springs on?
    You could go with EF hatch shocks, but if your wanting something more to a stock height I would go with the DA Integra shock/stut combo. They are designed to be more load bearing then the EF hatch shocks. They are fairly comparable to the actual OEM wagon suspension.
    I have a chance to get a set of 4 stock da shocks on craigslist: http://portland.craigslist.org/mlt/pts/2022009428.html
    These would bolt up right up to my wagon?
  • NZ-DB8RNZ-DB8R Moderator
    Yes and will raise it higher than standard when used with DA springs
    What kind of aftermarket suspension do you have? I may be willing to buy it off of you, if you want to part with them.
    Please do a search first.
    Ajr49123 wrote:
    ...will stock springs from an ef hatch or sedan work? ...other options?
    Read this link:
    viewtopic.php?f=8&t=4390
    Well I bought those da springs off craigslist for $70 (yes I talked him down a whole $10). Seems like a good deal, when I get around to installing them in the next few days I'll keep you updated on what brand the coil overs are if anyone's interested.
    Yeah I'd be interested for a good price. Or if you wanted to trade for something, good luck with the DA's.
    Well I replaced all 4 shocks with the da package. first off there were NOT coilovers on the car, there were stock struts with shorter springs, like nearly half the length of a stock spring (craigslist idiots). The car rides about 100x better now and I'm not scraping over every little bump. The only complaint I have is that the da rear shocks are a bit longer and the car sits a little high in the rear, and The stock rear tires have a bit of negative camber to them.
    Got any pics?
    Yeah I'll try to get some tomorrow. I could go snag a couple pics of the atrocities that I pulled off of there.
  • I'd like to raise mine too, only a little HIGHER than stock. I need extra ground clearance for the snow and rocks on those logging roads. An inch or maybe 2 would be enough. I've been looking quite a bit and get overwhelmed with all the mods available. Looking for the cheapest, easiest way to raise the ride. Adjustable coilovers are very expensive for what I want to achieve. Is it possible (practical) to insert a spacer at the top of shock mount? I am a machinist and have access to equipment, so fabbing something up is no problem.
    Thanks
    search around on here, i was just reading a thread about a guy making spacers to go under the shocks to raise his wagon. I think its the same member that fabed the 2" receiver to pull his quads, but I could be wrong.
  • Damn! I've got to sharpen my searching, found it. The pictures of the spacer on top of the shock are just what I was thinking of. Thanks
    Well here's e couple pics I snapped this morning.
    That's what I pulled off of there. I might look into some spacers for the front.
    Damn that thing is ridin' high! Good luck with the spacer build.
  • woodiwoodi Wagonist
    Oh man...DA rear springs look perfect for what I want to do. Fronts too low though. Need to figure out what to put upfront there to level it up. Then we can get some real tires under there and hope the little engine can get them moving....
  • GeNXGeNX Wagonist
    I love this. Can it still handle ok with a raise or does it roll?
  • running the stock DA configuration the car should handle nearly as stock with a bit firmer ride to it due to the added spring rate
  • GeNXGeNX Wagonist
    As far as DA goes does that mean off any Integra or just second gen?
  • DA would be basically any 90-93 integra
  • JackVJackV Wagonist
    lol, looks funny.
  • I applaud all the stump jumpers on here.
    What size wheel/tire are you trying to stuff up in there?
    BFG A/T's with a skinny side wall slightly stretched on a 7 or 8 inch wide wheel, boner time.
  • 3rd4ce3rd4ce Council Member
    i was gonna tuck a set of 27x9.50R14LT SSR on the RT white steelies
    but my brake upgrade made me go with a 15inch rim..
    so with the brakes and rims i didn't have enough cash for the tires but next time around WATCH OUT..!
  • byrne_06byrne_06 New Wagonist
    if your looking to raise your car more springs for a 96-99 ek are about 2" longer,not sure if they would work on a wagon shock or not but its worth a shot.
  • Ajr49123 wrote:
    I like how there was a wagon rear shock and a non-wagon rear shock on there. Bet that made the settings wonky. lol
