What head for most torque/low end power?
ive read that the y8 head has more low end power band do to its port swirl design(?) but just about everyone i read about does the z6 head(either whole block or mini-me) my goal in building up my engine is for a fun dd that had better low end power band for torque for in city driving and freeway passing. what is the best head to use for a mini-me? thanks guys
Honestly it probably isn't going to make -that- much of a difference on a fun DD that isn't built as an all out machine. I doubt that you'll feel the difference between 3-5 ft/lbs.
edit
Ya i read the title wrong my bad lol
Well in my option, The Z6 head is the way to go! But I'm bi-est because I have only ran Z6 heads!! and I'm have build and tuned my D16z6 engine to over 650whp!! Maybe someday I will try a y8 head?? But its been easy to get a hold of Z6 heads!!
Well two sides here..." its really up to you" that's the right answer LOL
Z6- older head, easier to get You have the open combustion chamber, some people like them due to more clearance for High comp pistons.
Y8-newer head, but shitty crank in ( y8 bottom, so still easy head to get, LOL, will "raise compression over Z6 head" closed combustion chamber, alot like most factory turbo cars come with, DSM's ect.comes with Bigger intake plenum too.
Please add... to my list???
I was getto
looks like i need to start looking for one. thanks guys!
you will bump up the displacement to 1668cc with a compression of about 9.6:1
that way you wont have to worry about converting to vtec conversion and you will have a better port flow. plus the y7 head uses aluminum rocker assembly so that will be lighter and help open up a minute amount of power.
just throw some p29 pistons into your a6 would be the easies of all solutions. your compression would be 10.79:1.
