Wagon rear shocks up front?
I recently found out that our wagon rear shock spring perch is about 2 inches lower than the front. that being said is it feasible to put rear shocks in the front with lowering springs all around to slam my wagon?
  • Have you had a look at the front shocks?
    VERY VERY VERY different to the rear shocks
    Lowering springs on Wagon shocks will give you uncaptive springs which to me is quite dangerous as the spring can "fall out" and not seat properly when the weight is taken off that corner
  • If you are wanting to go really low, I'd suggest saving up for a good adjustable coilover suspension and possibly these to fix the problem NZ is talking about - Hyperco Coilover Helper Spring
    Note: I have no affiliation with Hyperco, I'm lazy, and theirs is the first link that popped up on a Google search that had a picture.
