RT4WD; when warm, hard to get in gears but not grinding
I have an 88 RT4WD. When it's cold it shifts a little better but if it is warm it is really hard to get it into any gear. I have to really press. It doesn't grind at all it just but it feels like I have to pop it into gear. No grinding. WTF? Is there an adjustment on it? I am going to change the fluid on it today (and I haven't even had the car for a month so I never did check it) but I wanted to get everyone's thoughts... Thanks
This just started for me today. I have an 88 rt too. Are the only solutions changing the tranny fluid and checking the clutch pedal and cable? I'm afraid that my tranny is shot. Also, a week or two ago the spring to my clutch pedal broke off would that have anything to do with it?
Did u fix it yet?
if u haven't drive very scared...My transmission and clutch both exploded two days the getting stiff started.
Mine wouldn't grind either. Check fluid level first. Mine was fine, so was my clutch brakets... so just a heads up...
