Heater lights go off or on when switching fan speed
Anyone know why and how to fix the lights behind the heater knobs that go off when I turn the fan on. Sometimes the fan won't turn on then I turn the switch off and then on again and it works.
Gauge lights work fine.
  • your best bet is to get the heater cluster out and go through and check connections and replace bulbs
    cleaning all the contact points will help a ton also
