NZ-DB8R wrote: I have some, Will take a pic when I get home from work this afternoon, can give you measurements etc as well if needed
BillBoard wrote: rubber ones via ebay http://cgi.ebay.com/ebaymotors/JDM-HOND ... _710wt_936
yes please! ive never seen rears before :oops:
i've made a set of cardboard that im pretty sure are 99% but some areas im not sure how they are
thanks
Tape measure is hard to read in the pics, but total length was about 1340mm, if you need more detailed measurements let me know
cheers
could i get a few measurements:
width and height of the right side mat, the total length of the left side mat, and the width of the bridging part
lol, i need the pics NZ just posted of carpet mats. everyones seen those one! they've been on ebay for about a year lmao!
500mm wide x 455mm high
Left side matt (bridging part is part of the matt):
835mm wide x 455mm high
Bridging part (approx):
335mm wide x 180mm high
So basically the each side is identical but the left side has the bridging part attached
cheers
