One Valve is Bad and There is Not Compression on one Piston!
Hi guys! Last Saturday, I traveled to Connecticut (CT) from the Bronx (like two hours away). I was driving at around 65-70 where permitted. When I arrived to CT local streets, I felt that my wagon was running a little weak. There was not much power and the engine was shaking a lot. I tried by removing the spark plugs wire with the engine running to see if there was lost power in any of the pistons. I was right. Standing in front of my wagon and counting left to right, the piston # 4 was not working properly. Fortunately, the wagon took me back home but it was using more gas than usual. I checked by changing the spark plug and wire in that particular piston and nothing changed. Someone measured the pressure in all pistons and there was nothing coming from that particular piston. The mechanic told me that a valve went bad.
He charges me $250 plus head gasket and new valve. The thing is that I found somebody else who is willing to swap a 92-95 Civic SI engine for me for $500 (including full swap and labor). However, the same guy offered me to install a 96-00 Civic 1.6L SOHC non-Vtec engine for $600 (including full swap and labor). This last engine, I would have to install a new timing belt and water pump to it since this engine only has 95K.
I am not sure what choice to get. What I could probably fix with $300, it is going to go up to almost $700 if I decided to go for the newer engine. It may be worthy though. Please help me decide!
Thanks,
Update: The mechanic said that he never ran the 92-95 Civic SI engine, that he does not know if it runs. He said that the D16y7 is currently in the car and it is perfectly running.
Thanks,
Okay, I see...
I did not know... I thought that the newer the better.... My concern is actually durability/realibity rather than speed...
IMHO just do the z6. It's reliable "peppy" and cheap.
The only thing is that I am paying the guy to receive a working vehicle, if the engine does not run after it is installed, it is his problem... But I guess you are right....
So in your case it might be wise to find out why in fact that one valve did go south. Perhaps a plugged injector, etc. Because of course you don't want to have it happen again.
If it was me I'd stick with the stock original motor, at least you know it's history, if it's reliability you are after.
If you have a cracked valve guide that has to be replaced, and once you get a new valve it has to be seated so it doesn't leak. then reassemble.
Believe me, I know, I did it 3 times on my b20vtec.
Yes, I understand. That is why I think the second mechanic was suggesting me to change the engine instead... What do you think that it could be causing it?
The Y7 (106Hp) with 95K ($600.00 engine/labor + $75.00 OEM water pump + $45.00 OEM timing belt (to play safe) + extra $60.00 for water pump and timing belt labor = $780.00)... I may just fix the my current engine (92Hp) ($250.00 labor/head + OEM head gasket $56.00 + OEM cam seal $4.00 = $310.00 ONLY).
Great, installing a D16Z6 head on my regular D15 block without the manifold intake, would it give me a little more HP?? Please keep in mind that mine is automatic transmission....
d16z6 would honestly be your better choice for the money, just have him do a compression test and look at the timing belt & water pump for any signs of leakage or dry rotting, you will be alot happier in the long end .. 25 hp doesnt sound like alot but thats a 25% gain over using the y7
Yes, that is what I am thinking on doing. I am just changing the head (D16Z6). I am getting supposedly for $50.00 but the guy is charging me $200.00 to do the job. I do not know if I am being over charged knowing that he is only changing the head. I do not know how easy it is to change a head since I have never done it. But I do not really want to start with this one.
Yes, but remember that the mini-me would not work on its best because I would be using my regular same 2 injector manifold intake. Harness will be the same as well s computer. My wagon is automatic. I do not think that I would be getting much out of it anyways. I do not think that I would push the engine that much either.
If I do the d16z6 head with my current D15 block, I do not think that I would have to change the timing belt or water pump. The water pump and timing belts are almost brand new from Honda. I installed them like 5 months ago (6K miles ago). But let’s see what happens.
