Cable Transmission Problem
I have a 91 RTAWD which has a cable tranny. About 2 days ago it went into gear fine no problems.
Till yesterday I was driving it when all of a sudden i couldn't go into 1st anymore or any other gear...
I stomped on the clutch and no go still, so i turned it off put it into gear turned it on and worked. I got home
tried it again, no go, as i drove it up my driveway I couldn't get out of neutral. So I hurry and turned it off.
Put it in first and started it, as I was cranking her up the car was going with the cranking. Make sense?
Heard a grinding noise. SO i got her up and let her sit. I started her in neutral all fine....but when she is on & idling i CANNOT
go into any gears. When I start her in any gear she will start driving off with the starter as I am cranking it.
I tried tightening the cable and still having the same problem :evil: . I am stuck guys & would appreciate it if i could get some replies.
Sorry if it was so long just wanted to make sure I got most of the story covered. :? :?
You might be able to make some adjustment to your clutch cable to extend the life of your worn clutch, but a worn clutch sounds like the culprit to me.
What clutch would you guys recommend?
Just to make sure I want to see someone say what clutch will fit my 91 RT, d16a6 of course.
It's probably already mentioned somewhere on here, but I want to just make sure I don't get anything mixed up and mess my car up.
Search. There's several threads on here about that very thing.
He's right^^^
Cracked pedal bracket is still veeeery common.
I wouldn't replace the clutch till you try those to things. you might save yourself time and money.
But the clutch was working find before that's the catch. It felt damn good so maybe I'll look into the assembly.
