OIL light stays on
I have a d15z1 in the rt4wd, and I am getting a OIL light that only appears when I first start the car. It'll stay on for a 15 seconds or so and then goes away and doesn't come back.
Also, if I take a corner too fast it'll cause the Vtec oil psi CEL to come on.
Something I didn't do when I did the swap was transfer over the Oil pickup. I know I need to eventually (doing a gasket rebuild on a spare d15z1 that will be going in in a month). I am not blaming the oil pickup because I would believe it would cause problems all the time, not just at start up.
I did notice excessive oil caking on the oil pump. So I'm thinking that may be going bad. The other possibility is that the sealant I put on the Oil PSI sensor on the back was too much, or that the sensor is from the wrong year.
any thoughts??
any thoughts??
Are u talkin about caking on the oil pump screen?
i just replaced my oil pump also to try and fix this problem and it didnt help.
i noticed there is a difference between the a6 and z6 oil pan baffling as well as that the oil pickups have different part numbers. im going to be swapping in the a6 pickup tomorrow to see if this fixes the problem.
word to the wise, match the oil pickup to the pan! i hope this saves a lot of unnecessary work and headaches. cause i sure had a doosey of a time figuring this out.
I believe my previous d15z1 needs a rebuild.
