RT4WD how to drop the oil pan??
I just picked up a 91 rt4wd that had a turbo mounted (no charge piping installed yet). I want to de-turbo it and put it back to stock.
however, I need to drop the oil pan to take care of the oil line that has been welded to there.
I was peeking around and was baffled with how the hell am I suppose to get that pan off with part of the tranny in the way?
Any advice please!
-Shane
Any advice please!
-Shane
According to the Helms, drain the engine oil, the transmission oil, drop the prop shaft (front to rear driveshaft), remove the transmission bash plate, remove the transfer case, remove the clutch cover, drop the oil pan. Like Skinny mentioned though, if possible, just cap the fitting, unless you're anal like me.
DOHC ZC pans are the same as the RT4wd pans if maybe you know someone who has a spare.
If you plug up the hole you might want to make sure its air tight so you dont run it to crank case pressure problems, or worse oil some how getting out.
Right now I'm at the point if I want to invest in the turbo part of it, or if I want to drop a d16y5 as originally planned.
I'm not huge into speed/power anymore. I'm more into the fuel economy of a vehicle, but not to say I'm NOT tempted to run the turbo :twisted:
Ah so you're the one who picked up that wagon
good luck with the pan removal; any plans for the discarded turbo stuff?
Sound like a lot of work just to get it off! :?
How do you know about this one? As far as I know it was only posted on a couple local boards.
As far as the discarded turbo goes, debating putting it up for sale or holding on to it for future plans.
I read up on how to remove the oil pan, and if it wasn't leaking I would have just capped it off to save money and time.
Oh well. Probably Thursday or Friday I'll get some pics up of the beast.
life sucks...
then you get an oil pan
I saw it on craigslist. there is a site out there that lets you search all of craigslist at once!
basically i just need to get behind that part and then I'm good, but the thing is not even trying to come off!!
any tips?
not sure if this will show or not its a link from autozone but you have to be a member so I'm not sure if the diagram will show.
http://repairguide.autozone.com/znetrgs ... 0617c2.gif
I was debating jb welding but there was oil seeping out and I knew the jb weld wouldn't hold up with the oil.
either or its out! Now I need to locate a rt4wd or dohc zc oil pan to replace. I am going to hold on to the turbo stuff for a little bit and keep the pan tapped (get it cleaned up though) and turbo it in the future.
Turbowagonman did the mod many years back and it worked fine but I cannot find the pic.
http://yota1man.tripod.com/vtecwagon/index.html
take a hammer to it? I can get a picture of the oil pan if you can point it out
Hate to say it but if you want somethin that you can get the pan off easy get the FWD model. It may be easier to crack the tranny from the block but that sounds like more of a pain then removing the transfer case.
i had to do this just this past weekend cause im having oil pressure issues on my wagon.
i hope this helps, its not too hard, just time consuming.
I saw it on craigslist. there is a site out there that lets you search all of craigslist at once![/quote]
