SLow starting when cold, starts great after
My wagon is running better. I got the oil changed, put a new filter in. Found a few things that weren't connected right and connected them. EG the power to the squid looking thing with all the vaccum lines on the right front was disconnected?
So the low idle seems to have finally been vanquished with the oil change.
But I still have trouble starting first thing in the AM. Is this the distributor?
Battery seems fairly new but I suppose it could be the culprit?
Did you fix this issue? I have a similar issue on my carburetted stickshift '87 RT4Wd. Mine starts up great, revs to 2000 automagically until the choke turns off. At that point I usually have to give it just a bit of gas for just a second to keep it from dying when it revs down from 2000rpm to 800rpm. After I give it just a hair touch of gas it will idle. If I drive it at that point it will die when I put the clutch in and let off the gas instead of revving down and idling normally, i.e. between shifts & when stopping. If I sit there and rev it at 3000 for 30 seconds or so before I drive it I will not have that issue. It idles just a bit rough at all times and I notice that it surges just a bit occasionally while driving. I cleaned out the carb from the top by spraying it with carb cleaner through the mesh filter (without removing it). It seemed to run a bit smoother but not 100%. I replaced the plugs and wires and cap and rotor. It ran the same. When I was replacing the cap and rotor, I noticed oil in the distributor cap. I did some research and it seems that this is due to bad seals in the distributor and that the distributor should be replaced. It also seems to be leaking from the area where the distributor connects to the block/engine. This seems like it might be a distributor o-ring problem. I've ordered a remanufactured distributor from cardone (from autozone) so hopefully this will resolve the issue.
My theory is that there is oil in the distributor blocking the contacts intermittently and when revved the contacts inside the distributor push the oil out of the way. I also think that I might have a PCV valve problem. The new distributor comes with new pcv valve so hopefully when I replace the distributor it should resolve the issue.
If not my next try will be fuel filter/fuel pump.
also if i drive it for a while and then turn it off it has a really hard time starting back up, ive got to sit there and let it turn over for about 15-20 seconds then it finally fires up.
