Wagon exhaust system
I had a question about the stock exhaust setup on civic wagons. On my 90 fwd wagon, The header comes down to the cat and about 3 feet behind that there's an expansion in the pipe right before it curves to the muffler. That expansion has looks like it's been scraped and dented quite a few times from being lowered (just raised it). Well at about 1200 rpm theres a nasty rattle from that pipe, and when I get under and shake it a bit it sounds like something came off and is rolling around inside there. Would my best bet be to just hack that off and fab a pipe to replace it? Any insight into what exactly that portion is?
Replacing it with a straight pipe will probably give you a tiny tiny small amount more power and make it slightly louder.
