Need help stumble, bogging RT4wd D16Z6
I have a 89 wagon RT4WD 6speed with a D16Z6 swap with Z6 Intake manifold and convert to OBD1 with EBAY pig tail (OBD0 to OBD1) and running a stock P28 ecu. My problem is while in gear going at a constant speed freeway or city driven, once a while it will STUMBLE or bog or feels like it need more gas or air, and when it acts up like that and I feel it and I Flore the gas peddle and for a second or two it gets back to normal. I've check the ecu if theres any code and no code, I swap the throttlebody, swap MAP sensor, check the Fuel Pressure Regulator and even swap ecu. I also did tune up, (cap n rotor, spark plugs n wires) and still acting up. Any advice?
I know theres another tread like this but mine is a little different. thanks
yes i did use a 4 wire o2 sensor
I know the distributor is still good but ill find another 1 and swap it and see how it goes.
I did check the FPR but I have an extra 1 so Ill swap it and see how it goes.
I know i did do all the wiring right but when i have time ill check the wiring again, this i my DD so when ever i have free time ill take a look and do some swapping and I det you guys know if theres any change, thanks too all that input ur advice.
yes i did, the car doesnt over heat or anything. It mostly happens at warm temp.
I swap in another FPR and it hasnt be acting up but im thinking about replacing the o2 sensor.
