D16z6 swap using stock automatic?
Hello,
I have a 1988 2wd automatic. Is it possible to do a d16z6 swap and retain my stock automatic tranny?
It is about the same as doing a multi-point setup.
I kept mine auto with an Si intake and throttle body. Using A6 Pieces. I am going manual with my full A6/Z6 swap with Super Charger
You will need to get an ECU for for a EX auto.
I'm still debating on the LS swap and converting to a manual at the same time.
I'm right at about 50/50 on this decision:
1. Swap in z6, stay automatic, save money?
or
2. B18b1 swap, convert to manual, spend more money for 20-25 more hp and torque?
My goal is an economical, reliable DD with some more pep-in-its-step than stock.
Any opinions guys?
When I throw in my swap, I am throwing in an HF trans and going for highway cruising speeds. The Supercharger will just help me out with getting up to speed.
wago_dan just scrambled my brains with some practicality.
LOL...
I eliminated the auto lock control solenoid..
I will say, that my auto was a big surprise for other autos. I can roast the tires on take off and 40-60 jumps aren't bad either...
also did you have to do the oil pan swap? what about the driver side mount?
please direct me in the right direction as i am ready to get this swap going in. thanks
Drivers Mounts are the same.
Oh, and I eliminated the Auto Shift Lock Solenoid, in the shifter(which lets you shift gears)... Not the trans.. When I converted the harness, I could not figure out which wire controlled the shifter lock, so it was very easy elimination, or else I would have had to have a spare key in it all the time..
