RT4WD differential mounts
Hi, I actually have a 1999 CRV RT4WD and the mounts on the rear diff are worn out. I was cross referencing parts and saw that the part numbers are the same between that model and the ones found on your wagons. I can source oem replacements just fine but was wondering if anyone has found poly mounts that work? I can't seem to find poly components for either the CRV or wagon. Thanks alot.
Civic items:
#5 50711-SH9-020
#8 50713-SH9-010
#10 50721-SH9-010
CRV items:
#3 50711-SH9-020
#4 50713-SH9-010
#6 50721-SH9-010
So you see that civic item #5=crv#3, civic#8=crv#4, and civic#10=crv#6. If I can source the poly components for your civic wagon, they should work fine on my CRV. Pics:
CIVIC:
CRV:
Stock replacements will be much more comfortable. As I doubt you're turning it into a race car...
Either way, I want information about these parts in poly so I can make a decision. I may find out that the pieces don't exist, who knows.
