Could these be symptoms of a partially busted clutch pedal
When doing my booster swap I noticed that a previous owner had done a kinda half assed reweld on my pedal assembly. My wagon doesn't like to slip into 2nd gear(especially on a downshift) and it has the same hard time being put into reverse.
Would that be a common symptom of say maybe a pedal fix that isn't done quite well enough?
Also... how much of a pain is it pulling the assembly to reweld everything up (just for shits and grins).
Take some pics and post them up. It will be a lot easier to see exactly what you are talking about.
I was hoping my symptoms were as easy as a quick weld up to fix.
I
Looks like its time to cram my head under the dash again and get a closer look at the pedal assembly
What's wrong with this picture/ explanation????
Reverse gears don't have a syncro! I'm not totally positive about this, but have no idea why any auto manufacture would put a syncro on a reverse gear. They don't put them on a first gear, and there's a reason for that.
So I come home after work. I don't have a working flashlight (kids!) But I can see a part of the pedal cluster flexing when I push in the clutch pedal. Welded good enough to hold together but not good enough to keep from flexing.
I'll have to confirm all this by pulling, rewelding, etc.
So... How much of a pain is it to pull the pedal cluster?
Haven't even had time to stick my head under there to estimate the time it's gonna take to pull the assembly out.
it's pretty easy to do. just really takes a toll on you and your back. if you have a good back and really steady hands, total swap out and in in and hour and a half.
good luck to ya. and again night and day difference. you can even set your clutch cable properly. best upgrade by far.
Should the left side of the pedal cluster have any flexablitly to it? It does flex some when I'm pushing the pedal.
Now I'm thinking maybe it's something else. Quick history....
1. The car got a new clutch not long before i bought it.
2. I found a second clutch cable in the back of the car.
3. Even when i adjust the clutch cable as tight as it goes, there is still a little slack in the cable
I think i read on here that the rt4wd take it's own special clutch, pressure plate, and throw out bearing. Something like that.
So lets say that the person that did the clutch job didn't get the right rt4wd specific parts. Would any of that result in a clutch that you aren't able to adjust tight enough?
I started to wonder if the clutch was done with the wrong parts, and then the person that did the job thought that maybe the clutch cable was streched, so they replaced it. (and that it's still not right)
I'm really thinking it's a problem in the clutch or shift linkage, and not something with the transmission itself.
