Trans swap?
I'm getting tired of this 25-28mpg I'm getting from my rt4wd. It doesn't snow around here, and the second gear syncro on my trans is getting a little on the crunchy side. I have to do a lot of driving every day, and I get a strong feeling that it will not be that long before gas prices are back up again.
I started looking at the faq at the top of this forum. So the final drive on a rt4wd is 4.4. More than even a crx trans at 4.058. Add that to the extra drag of the 4wd system and that explains the bad mpg's. (I think, just starting to educate myself with honda transaxle stuff)
So.... What all does it take to convert from cable trans to a non cable. (i assume the others use that more common honda linkage). I know about taking the rear end, viscous coupler. My question mainly centers around the linkage.
I've got a a6 shortblock that I'm in the process of rebuilding. I'm running a fresh z6 head on my current tired a6 bottom end. I figure instead of changing syncros when I'm swapping the bottom end that I could just have a trans waiting to go.
I just think once I swap into a standard trans that i'll prob never really miss the rt4wd.
I hadn't really thought of this option till I drove my friends 92 teg with a b20 swap a few days ago. I almost felt embarassed when we started talking MPG's. That car flat flies and gets way better gas mileage than my little wagon.
I thought we already determined that this didn't really change your mpg much?
I'm not sure if, due to our cable trans, we have the mounting points of the linkage assembly:
I'm sure you could mount them, but you would also have to cut a hole to account for the shifter coming through the floor. We might have a punch out area that never got punched out, but I've never really looked hard enough.
pm me
More heresay...
i get around 30-35 city/highway combined milage in 2wd and 25-30 in 4wd.
