New guy looking for RT4WD.
Hello everyone,
Been lurking here for awhile but on the hunt for an RT4WD. I might have a line on one up here. What do you think would be a good price for auto, 135k, some rust on a back panel? Haven't had a chance to look at it yet, but wanted to get an idea. I don't have access to the marketplace forum, and otherwise just seen a few random things online. Any help would be great, thanks!
For a price recommendation, I would need to see a few pics. 135K is kind of low mileage for a RT4WD, imho. Mine has 100,000 more miles on it.
The front seats have seat covers, the drivers is pretty worn underneath, split with the foam exposed. The rear doors seem to be a little tricky to open as well. And the drivers side window sticks when rolling back up.
Does that all seem like fixable stuff, body wise? The engine feels great, wasn't near a freeway but got it up around 60-65 on some rural routes and the car felt pretty good. I did hear some rattling from the rear, maybe the trunk not latching tight enough?
Uploading some photos. I'm also going to take it to my mechanic next week to get it checked out. Thanks for all the help!
Do you have any plans to mod the car or are you going to enjoy it in stock configuration?
i'll probably keep it stock for the most part, especially since it's in such good condition.
one bummer is that on the drive here i started having trouble shifting into 1st, and also got stuck in reverse once. i'm having my mechanic check it out, hope it's an easy fix like a cable adjustment or some grease or something. weird, it shifted smooth when i test drove it. that's always the way i guess.
so... i'm still having clutch issues. the guy i bought it from said the clutch was less than 2 years old but i'm having trouble shifting into first at stops. my mechanic thinks it needs a new clutch ($1000!), i'm pushing them to check the "base plate". we'll see. trans fluid changed to 10w30 as honda recommends, also flushed so it's not that.
also, we noticed that the viscous coupling box is getting really, really hot. drove for 20 minutes, and after sitting for 20-30 minutes it was still hot to the touch. is that normal? the guy looking at it thought it might indicate transmission issues? everything feels fine on the road other than the clutch issue.
thanks again!
Might want to find another mechanic... $1,000 for a clutch change is a rip off.
Obviously you've never tried to change a clutch in an RT lol
The people I bought my car from, put a new clutch in it right before I bought it. It cost them $800.
Some thing are just better to pay to have done, and save the headache. I'd do the clutch myself, but I'm experienced. I would highly recomend NOT trying to do this yourself if you're an amateur. A lit harder than doing a FWD clutch swap.
so, the car does mostly shifts nicely, it's just when going from neutral to first at a red light, it sometimes wont go into first. i just figured out that if i then try putting it in reverse for a split second, it grinds a little, and then will go into first. does that sound like the clutch base plate issue? i'm considering a 3rd opinion. refuse to believe i'm imagining it.
Next might be looking into performance upgrades. Anywhere basic to start? The engine does use a fair amount of oil, any ideas about that? No leaks that I can see, but I run about a .5 quart per fillup.
Also recommends for roof rack if anyone's found one that works well?
Thanks again for the awesome info!
ron
