Stumble/ misfire/ stuttering acceleration feeling?
My car has started doing this strange intermittent stuttering feeling thing. It does it at idle, and as I'm driving. there are no check engine lights and it only does it after the car reaches normal operating temp.
Car is an 88 wagon with a 95 d16z6, obd1 and auto tranny (car does the stumbles while in gear AND with the car in park or neutral)
I tested and cleaned the IACV, TPS and installed a throttle body that has no FITV and the problem is still present.
Thanks in advance.
Thanks in advance.
I'm tempted to keep one in the spare tire well as a spare with the estra main relay. 10 minutes to change.
I'm in san marcos - but don't have a spare distributor. You can try mine?
Possibly a bad ecu. Also if you have a dvom you can run checks on your dizzy fairly easy. Whenever I put in new motors or get a new car one of the first things I do is a tuneup (plugs, wires, caps, rotors). Not sure if you did. Something to check out.
Faulty injector/injectors or fuel pump?
Replace cap, rotor, plugs, maybe even wires if you have the extra cash.
Had the same problem with my Mom's Oddessy, and my neighbor's EG.
Cheaper than a distributor. Coils and control modules are the reason distributors are so expensive, so if you can determine that it's either, then a new distributor is in your future; and they come with new cap ($15) rotor ($12) module ($76ish) and coil ($60) > $125 for whole new distributor versus rebuilding
ehhh woops... :oops:
My wagon has same problem and I also suspect faulty injector. Did you fix it? Is it becasue of faulty injectors?
