ITR suspension on Wagon?
Has anyone got ITR OEM suspension on there wagon?
I know it raises the HB/CRX slightly, but should drop a wagon nice??
thats oem ITR shocks and springs?
i found this pic from where he did the conversion
Will probably raise a Civic Wagon if anything
i know it makes a Civic HB/CRX sit higher. FYI ITR suspension is the same as fitment as EG
DC/EG front shocks are longer than EF so that will raise a Shuttle/Hatch/Sedan. The rear I cant remember but likely do the same. An ITR is only very slightly lower than non R Integra.
yep certianly would. i had thoughts of doing that myself as ITR suspension is readily available here.
The front knuckle can swap, but If the EF EX bearing has the same bigger center as say the DC2 or 92-00 Civic EX bearing, the ITR hub can be pressed into that bearing, making it easier.
As for shocks, the ITR uses an eyehook rear shock to bolt, so the 88 CRX LCAs can work, fork type rear shocks don't fit stock.
