Eliminating Viscous coupling unit?
so i removed my driveshaft due to some vibration and noticed the rear u joint is shot. im prob going to replace them all. but first off, i was wondering if there are any faults, or something that will not work properly if i just make a customize one piece driveshaft eliminating the Viscous coupling unit and of course keeping the u joints only at each ends?
i also noticed this driveshaft is FREAKING LONG as heck, so doing a one piece, does that mean there will be a bigger chance in vibration?
The reason for the diff issues has nothing to do with the driveshaft. It has to do with the different ratios that the front wheels are driven versus the rear wheels, so when going in a straight line, or turning, the front wheels fight the rear wheels because they're trying to turn at different speeds. The Viscous coupler allows them to do that - turns at different speeds. A solid 1 piece driveshaft will not let that happen.
If so couldn't we change the gear ratios either in the front or rear to match each other, install a standard driveline and just run open diffs without any problems? .....
And if you really wanted traction , install LSD's in the front and rear....is this plausable?
thoughts?
an explanation even I can understand...your the man....I thought the VC's main purpose was fuel economy,now I know its more involved...
