Anyone running a Y8 Intake Manifold SUCCESSFULLY on D16A6?
I dont want to do a Mini Me swap. I have a head and just dont want to go through all of the trouble...plus, my A6 is a champ. not one problem at all. Its my ol' trusty and just wanna spiff it up.
my question is: has anyone successfully installed a Y8 IM on the stock A6 head and have no problems? Im keeping my car OBD0, and just wanting to install the manifold, fuel rail and throttle body from a Y8 for a bit more power. If you have, please let me know what needs to be done for it to work correctly. And what needs to be capped off and what lines go where.
Much thanks!
-m
Much thanks!
-m
Forgot to add the one that has the extra vacuum ports across the runners is useless!
Please explain and elaborate for those of us on the short bus. :oops:
Are you refering to a third type of manifold? Or a production run of both auto and manual manifolds? Or produced certain years?
An interesting thread... thanks for the info so far
Need to know what else I'm in for before I pull the mani.
I have a manual IM as it is the two wire..
Not necessarily. You could simply plug the ports where they meet the head.
Interesting thread, and happy to say, I think I even understand. Thanks!
Please and thank you!
Poor flow, Y8 manifold on my z6 radically change my power band!
I have a y8 IM on my d16a6. When I put it on, i didn't know about ones with vacuum holes. If you were to install it without plugging the holes, what would happen?
EDIT: Made a call and was told it's from 98 without EGR ports, all is good. But yes, i've done it successfully as well.
