Rear wiper delete
I wish to delete my rear wiper from the hatch but after taking the panel off and the bolts it still won't come off. My question is, Is there a clip or something holding it in place? Am I able to delete this? I have a rubber piece to fill the empty hole but I just need to take the wiper out. Thanks for your help.
    Did you take the arm off (outside)? There's a nut under a plastic cover.
  • i just pulled off the arm outside, pulled the inner pannel off and unbolt it,unplug it and it just pulled right out. is it loose in there or still solid feeling?
    Still solid. I tried twice already to get it off but it feels like there is something else holding it in.
  • You didn't answer the question: did you take the arm off yet?
    Also, how many bolts did you remove from the wiper motor?
    Inside the trunk lid itself was 4 bolts. Is therre a bolt on the outside for the arm or something?
  • Did you take the arm off? There's a nut holding the arm onto the wiper motor.
    ^^Yeah finally got it off today. The stupid piece that covers it was stuck on there pretty good so I pretty much had to rip off that piece to get to the bolt. Thank you though, you've been a great help.
    Delete please
