Battery light fault code?
My battery light is flashing at me 3,2..3,2.. i couldnt find any of the fault codes.Any help?
I've changed the battery and the alternator already.
  • I don't think battery lights flash fault codes. Have you recently done any other work to the car? If so, double check you chassis grounds and ground at the thermostat housing. Make sure they are clean, free from rust/corrosion and tight. If those are fine then have the battery tested and test your charging system voltage/amperage output. If all that checks out, then you may have a bad ELD
    (electrical load detector) which is integrated in the under hood fuse box.
