New Guy Ventura CA 88 RT Wagon manual high revs on hwy
Hi all,
Heard these were fun, giving it a try--mine does about 3500 rpm in top gear at 70 mph-- I'm looking for another lever to throw!!
I'm guessing it's the gearing for 4wd, or else something is stuck--
Wheels are little 13's too, which isn't gonna help.
Thought to ask you guys as you would know--is this normal?
Thanks,
Thanks,
As said above, dont worry about the revs, my Integra would be doing about 4300rpm at 70mp/h.
Body has some rust issues, and it's over 200k miles, but it is fun to drive, just need to tighten up that shifter somewhat and squirt some silicone ( around front windshield--really ugly rust there) and just run it like a trophy truck. =P
Oh ok, good to know.
Long story short, those rims are too small (RT's are 14" OEM) and will make the engine rev highER for the same speeds, HOWEVER, Hondas all rev pretty high anyways. I'd say the difference at 70mph may be only about +/- 500rpm between 13" and 14".
At highway speeds I'm wishin for a 6th gear too... and not SL!
Well, that or maybe I'm just easily amused.
i would have to concur, i too did this testing; noticed the difference and stuck with 14". Not to mention it rides a spec smoother w/ 14".
