I know FWD/4WD conversions have been done. But I have no definite answer as to the firewall and rear floor pans being the same? I'm guessing yes, but still wondering.
the 4wds have holes for the shifter cables to go through the fire walls and one major difference in the back is that on the 4wds there is an access panel to get to the fuel pump but the 2wd's are just like a any other civic from that era they have no access panel for the pump.
As anyone ever bolted a 4wd rear crossmember on a fwd wagon? Or the other way around. It would answer a question I've been asking myself for a while. I just want to know if the holes for the bolts are at the same place on both of the crossmembers? I know they are different in shape...
Thanks for the info...
did a search looked threw 12 pages with no luck.
here is the link.
Perfect! The blurb at the bottom has what you are after.
