Headgasket issue seems resident in Shuttles?
I have owned 4 Shuttles', ranging from 60,000miles to 160,000 miles on the clocks. Two 1.4 GL, one had a blown headgasket, and two 1.6 4WD, one had a blown headgasket. I found one JDM 4WD at a scrapyard - blown headgasket. I'm sure Nominous had a 4WD with a blown h/g.
And today, I've got word of another 4WD that has blown the engine.
What's the deal?!
:shock:
What's the deal?!
:shock:
Ahhh ok, that makes sense.
Whats the difference in the two?
+1
UK models don't have A/C though
and i've seen UK ones with blown h/g
I could also say I have seen just as many opels and bmws with blown headgaskets. Does that make it a opel or BMW issue? I think it comes down to who owns it, how they drive it, and if they care enough to do proper maintenance.
well here in the UK, there are sweet FA shuttle's about, and headgaskets seem to be popular failure among UK ones. but prehaps just bad luck, not looked after
24 Hours of LeMons Website
97-047
November 10, 1997
Applies To: 1988 - 95 Civic - All, except VTEC
Head Gasket Leaks
(Supersedes 97-047, dated September 29, 1997)
PROBLEM
The head gasket leaks oil externally or allows coolant into the combustion chambers.
CORRECTIVE ACTION
Install the new style cylinder head gasket and the new head bolts in the Cylinder Gasket Kit listed under PARTS INFORMATION. Use the cylinder head bolt torque sequence described in this bulletin.
PARTS INFORMATION
Cylinder Gasket Kit: H/C ***0031
Kit includes:
Cylinder Head Gasket (new-style):
P/N 12251-P01-004, H/C 4489530
Cylinder Head Bolts
(10 required, use with new-style gasket):
P/N 90005-PM3-004, H/C 2894988
Is that for the D16A6/7?
i cant seem to find the head bolts under that part number :?
lol yeh I could, but Im not made of money
even from honda, just the bolts will be £70!
I bought and sold a D16 set for $80 NZD.
i ring them up to order the new headgasket
the part number i took from a Honda bulletin that says this new h/g is for ALL Civic's 88-95 exl. vtec (12251-P01-004)
but he tells me its for 91-96 civic 4dr. and gives me the part number 12251-Pm5-S02 which i tell him is the old composite headgasket
then tries to tell me Honda h/g never fail lol
they all have the same fucking engine anyway!!! :x
so ive done some digging, and found this little quote:
so if i order the new style will i have to have the new bolts?
i dont understand why use the old style if yours inst leaking (mine isnt) if the Honda bulletin says that parts been superceeded
man this is stressing me out!
dont think ill bother getting it replaced
Head bolts:You're suppose to use new bolts or studs 'cuz the old ones stretch ,but people do reuse the old ones.
Composite h/g:This is what we have.These don't hold up as well as the metal h/g(read next line).In most cases(for average drivers) these hold up well,but pushed...
Metal h/g:The 1 you want.It's basically the '92-'95 Civic Si EX metal h/g.I believe this what Honda dealers now use as standard h/g replacement.
The 91-96 civic 4dr h/g(you mentioned):If this the y8 h/g I'm thinkin of can be used,BUT may bump your compression ratio.
ok thanks, thats starting to make sense.
but they wouldnt replace it with the metal one here in the UK, as they type in reg number and order the part that comes up (which is the PM5-S02 p/#)
might be a stupid question, so forgive me, but will bumping the compression by using the new metal h/g alter anything, or require anything else?
i thought honda head bolts dont stretch?
Someone please correct me if I'm wrong but...... pretty much any bolt/stud that is that long is going to give a little bit (stretching/twisting), just because of the nature of the metal and the dimensions of the fastener. On a lot of 4 cylinder engines, the head bolts/studs are actually SUPPOSED to stretch/twist a little bit as a function of how you torque it down according to factory specs. I believe this helps to hold it in place against vibration. I know that is why a lot of times people say not to reuse the head bolts/studs, but I do not know if that applies to Hondas.
As far as bolt stretch FSM makes no recommendation of bolt replacement,but later K20a engines actually have you check bolt dia. @ 2 different spots on the bolt for stretch.Just make sure you oil the bolt threads & under the bolt head b4 install.The torque specs are for oiled bolts.
thanks for the replies guys, much appreciated
