posi?
ok i have a 91 waggon and it seems like both rear tires spin on the ice and snow and has alot of traction. now my 88 only 1 tire spin and doesent seem to grab as good.and the 88 has new tires and 91 r about 1/2 tred at best. also 88 is stick and 91 is a auto. so is there lsd in rear?
im not sure if this applies to you, it might just be the JDM wagons.
The weight might be a factor(weight transfer).The '91 is a lot heavier(300 lbs(140kgs)).
Check this link for more on the posi:
http://www.hondacivicwagon.com/board/vi ... .php?t=595
