Wheres the door open beeper?
its getting anoying i know about the little black box button on the ignition switch. but i want to find the beeper and reuse it for a headlights are on beeper. anyone know where its at? i need one of those doctor things to find it. thanks.
  • AG17AG17 Band Wagon
    i thought most hondas if the ignition isnt on and your lights are it beeps?
    nope. at least, not the USDM wagons.
    my friends EDM CRX beeps when lights are on, so did my DA integra. none of my civics though
    i do not know where the beeper is though lol. i guess just listen for it? :P
  • On the hondas that have the beeper, it's in the black box that is snapped into the back of the under dash fuse box. If you remove the black box, pry it open, you'll see a little speaker soldered to the circuit board. You can use a desoldering tool to remove it. That is something I have done to all my EGs, my DA, and my current DC.
    I also rewire the clock to accessory power so that I can have the clock on in the first key position when I'm sitting in the car listening to the radio but I don't want the idle motor etc powered up (key in the 2nd position).
    It's all the little mods that make a good car great.
  • Did you know you can turn on the clock display without the key in the ignition just by pressing down on the little plastic cover over the time setting buttons?
    I stunned my friend with a DX when I cancelled the forgoten key / door ajar alarm by simply pulling the keys out of the ignition, then puting them back in again .
