Loose steering ?
After my trans swap in my rt it seems as though my steering has become really loose... I thought maybe something wasnt tightened all the way under there but I double checked and it looked ok... i think maybe my rack and pinion is going... im just not sure... anyone have this problem... its almost like my power steering works to well..... im not sure if this post is in the right spot but its a start.
    Check the mounting bolts for the steering rack. There's a sheetmetal cover you'll have to remove to see them.
    BUT FIRST...triple check everything you disturbed. Ball joints tight? Axle nuts? Radius rod?
