STOCK replacement springs.
Hey all, after sorting through threads, and using the search function, i still cant seem to find a supplier for STOCK springs. front springs (from what ive gathered) i can use from a sedan/hb/crx, but rears you cannot, correct? i have found some Moog rear springs (part number cc259), however im almost certain they are only for the sedan/hb. if this is correct, can i use stock shocks from a sedan, with this rear spring set, and still maintain stock ride height?
thanks all. ive got two weeks, then im driving from san diego, to the tip of washington. definetly need new springs and shocks. the shocks have been easy to find, its the springs that are a pain!
Front or rear collapsed?What year?
Lower shock bolt came out?
Spring broke or snapped ?
Upper fork bolt fell out?
