STOCK replacement springs.
Hey all, after sorting through threads, and using the search function, i still cant seem to find a supplier for STOCK springs. front springs (from what ive gathered) i can use from a sedan/hb/crx, but rears you cannot, correct? i have found some Moog rear springs (part number cc259), however im almost certain they are only for the sedan/hb. if this is correct, can i use stock shocks from a sedan, with this rear spring set, and still maintain stock ride height?
thanks all. ive got two weeks, then im driving from san diego, to the tip of washington. definetly need new springs and shocks. the shocks have been easy to find, its the springs that are a pain!
    Why do you need new springs?
  • Why dont you just use the stock springs you already have? they're probably still functional.
  • yeahdannyyeahdanny Band Wagon
    one corner sags about 4 inches.
    Sounds like more than sagged springs.Take a L :shock: :shock: K.
    Front or rear collapsed?What year?
    Lower shock bolt came out?
    Spring broke or snapped ?
    Upper fork bolt fell out?
    it's the driver's side front corner. i have a feeling that it was just a daily driver for all of it's 260k miles, so that spring wore out. ive changed the halfshafts in it, and didnt see any real difference between the sides. the wheels are equidistant from the top of the fender when its jacked up, so that leads me to the conclusion that it must be the spring.
