Beef up (4WD)drivetrain
so i have searched for some threads on beefin up the rt4wd drivetrain but havnt found much. is there anything i can do to the tranny and rear diff to hold up to about 350hp? im not worried about axels and driveshaft, just gears and internals. I really dont want to explode anything. let me know
if this isnt an option i might opt for just putting my built motor in something else and going back to stock. thanks
Oh and by the way, in your sig you spell it "LOSE," not "LOOSE," and you are missing a "with" inbetween the "one" and "the."
haha thanks! im glad someone pointed it out. im am very grammically handicapped
look @ this wagon... viewtopic.php?t=9088...
or here ..viewtopic.php?f=5&t=7246&p=81383&hilit=rt4wd+tranny#p81383
i just did a quick tranny search
both of which i have read. bisi's is only FWD and jaker's is all custom.
This might be a good thing(the bad transfer drive gear).Rather than replacing it with a stronger gear(most likely custom made$$$$) which means something weaker would break like something inside the tranny(major work).Reason to leave it be:If it does blow.Shift out of 4WD mode.You have 2 options.Choice #2(not 2A) being the best well except for towing:
1)Limp home with a lotta noise.
2)Change out the transfer drive gear.The gear is easy to replace w/a minimal of tools.ADD OIL(10w-30 will do for a emergency,but switch back to Honda MTF later).
A)Remove transfer drive gear cover.Clean out the broken pieces ,refill oil & limp home.
i plan on eventually eliminating my viscious coupler so it will be full time 4wd.
what is your plan to do with all that power? (auto x, rally, DD)
i dont me to sound noobish but im far from it. the only thing i dont have alot of experience in is trannys, tranfer cases and diffs... so ill dig my hands into this thing and provide as much info as i can to help myself and others i guess.
1)I am interested in a possible mfactory rebuilt transfer case - do you have any info - do they have kits or is it custom?
2)Another question would be how do you eliminate the viscious coupler? What replaces it? I thought (from research) a full time 4wd conversion would create some serious understeer or oversteer problems? Please clarify. Thank you
read this: http://en.wikipedia.org/wiki/Viscous_coupling_unit
if the tranny casing was braced enough we could just eliminate the coupler and have direct 4wd full time. i would either add a spacer or do a one piece drive shaft.
these are mostly future thoughts since right now im building the motor.
can you transfer that wiki link to english lol
what do you mean about a spacer or one piece driveshaft?
I work in huntington beach do you know the name of the place, or contact #
I actually like the dual drive shaft and mounted VC setup. It allows for some travel in the shafts.
Sorry...The process is called WPC.
MKS Engineering
16631 Gemini Lane
Huntington Beach, CA 92647
Tel 1.714.848.3003
www.mkseng.com
Someone suggested mfactory but it would be custom - expensive....
i think jaker has already covered the fact that the teg gears and other fwd d16 trans have a different size when compared to the rt4wd ring gear.
I have not had the chance yet to see if B series gears will fit the 4WD shaft/bearings/synchros, and if they don't I think the ones from the D16A1 (1986-1989 Integra) might.
thanx for the info
Rotfl
