1991 4wd wagon turbo mod
i have been asking around how to do this and have not received much info or reply back about doing this particular mod. so i am going to start this tread and show how i am pregressing with this.
i am installing a brand new greddy kit 92-95 into my 1991 4wd stock civic.
pics will come as i can take them. if anyone knows more about this please post up on any info i can use as i am very new to this car and mod. i love to learn.
the reason is because i just got the whole kit sent to me and its missing a couple of parts that i can just tell right off.
again this is a brand new kit straight from greddy with their special tape, that has their greddy name all over the tape.
im missing so far, instructions/manual book for install and use.
the exhaust manifold
the mini right angle pipe that connects the down pipe and turbo.
as for other stuff i dont know if missing anything else yet because the instruction book should list all the parts that supposed to be included but since i dont have that i dont know whats really missing. this kinda sucks.
i also asked if i need to get injectors or can i just keep the stockers. he said since im not looking for massive power i can just keep the stockers for now and it will run just fine. that sounded great with me because i just wanted safe and reliable power so in my mind i only want a total of 130whp. then i asked would greddy's emanage work well with my ecu. he said as along as the ecu is hooked up properly it will work fine, again since im not going for huge gains ill be fine. im happy to know that emanage blue version would work out because its included in the package of parts i got from greddy.
so the next goal is to fine a place that will hook up the wires to my ecu, if thats even possible without any headaches.
pics will be taken on monday.
i also found a great place but not cheap by any means, that makes a direct connection harness specifically for the emanage to any obd port such as our obd0.
its kinda expensive but i dont mind as long as it takes the guess work out of this whole thing a bit more and i love how things just bolt up or just connect right out of the box. :P
the site is called boomslang fabrication.
they have harnessess fabed for alot of different applications. very impressive.
http://www.boomslang.us/index.html
the harness is about 190.00 but its worth the money for me at least but if there is another site that does it exactly with less money ill be down for that.
If you run FMIC on my s13 you would have to relocate the battery due to where the piping runs but this eliminates that. (Just thought I would explain a little more) Hope this helps.
LOL...actaully, if you run a FMIC on a S13, you dont have to Relocate the battery at all
Hit up Marcus at Heel and Toe...Cool ass dude...
