Tires.
Tires are hands down the best mod you can do to make your car handle better. If you can't afford stickier tires, then a moderately lowered suspension with good struts. If you can't afford that, then you probably won't see much improvement in any one piece (tie bar, strut bar, sway bars.).
get rid of the roll. want it to handle better through the turns. not ready to lower it yet.
might do that later.
don't have a bunch of $$ to spend so i thought this would be the most bang for the buck???
any suggestions are appreciated.
what to start with etc.
thx
