Main relay ? Ground ? something else ?
For a while my car was giving symptoms of the main relay going out, was having trouble starting when warm.. Last night she stalled on me, and the when i tryed to turn the key to restart it , nothing happened.. Was like it lost power to the starter. But the lights, and radio were still working fine at the time. Also lately ive been noticing my headlights seem to get dimmer every once in a while, and today my head unit seemed to be kicking out on occasion.. Im baffeled, anyone heard of anything like this before ? I havent checked the ground or relay yet.. Wont have time till the weekend.. just wondering if anyone knows if a relay could cause all that or if i should be looking elsewhere ? Thanks for any help
I'd say have an alternator test done. It's very simple if you know someone with a battery load tester/alternator voltage tester or even a volt meter. It should be charging at about 14v, and make sure to check it with and without every possible accessory on such as high beams, rear defroster, stereo, a/c, etc. and see what it does.
had just got the wagon running went down a back road about 45 mph and my engine died ..... drifted off the side and it would turn over but would not start.....
so we started checking into it ...... had spark but brand new Walbro255 was not running had no juice ....
needless to say we swapped back to the old main relay and the fuel pump kicked on and away we went ...
got it replaced free.. and i have the new one n now and keeping my old one as a back up...
