I bought my wagon but the crashed it into a curb
Okay my diver side rear wheel is bent in. I changed the lca and it straightened out a little but the cat still shakes when I go about 60mph. I need to replace the test break hub because that wheel bearing is in there so I'd figure just get the hole knuckle from pick a part, but will the ef hub/knuckle ,so will it just bolt on ? Is that an interchangable if not what do I use?
