(alt.&chk.lite)Question
it seems everytime i take my wag out for a drive the battery light comes on. her is what is happening. ill go to work which is only about a 2 mile drive. the battery light will come on or flicker. and it seems that when my engine gets warmed up that if i shut the car off and try to turn it back on within a few minutes of sitting it off the check engine light comes on as well as the battery light. its not running and codes when i pull the carpet back to look to see if the light on the ecu is blinking. so i got a new battery two days ago and everything seemed to be ok. today i went to go pay my ren and its about 10-15 mile drive the battery light flicked once. and when i cam out of the office after being in there for a couple of minutes the check engine light and battery light stayed on ! is it the alternator a short or some thing else? i have no idea.
I replaced the alternator on mine recently. Last winter, when the car was cold, I would have the alternator light below 2,500 rpm. It would go away when the car warmed up. I just decided to fix it before I got stranded somewhere.
http://www.hondacivicwagon.com/bb/viewtopic.php?f=10&t=4904&hilit=brushes
As far as the Check Engine lite it could be a seperate issue.
