86 Wagon in Oakland
I picked up an 86 civic wagon this week in Pleasanton. I live in Oakland CA and work all over the bay area. I am hoping the car gets good mileage!
I also really like the fold down seats cargo area. I plan on using it for my band when we play out.
I already noticed a couple of issues that will need addressing.
The brakes are kind of soft. Like air in the line or something.
The tranny has a slow leak. Not sure where I can check tranny fluid?
Stalls at stoplights every now and then.
The radiator fan is busted. Not sure if the fan itself is broken or if there is a control mechanism.
look forward to combing through this forum for answers.
I always have wanted a honda and am stoked to have one to work on now.
Only 86k miles too!
Only 86k miles too!
Bad news, I am seeing more water in the exhaust lately and I had a crazy overheat episode yesterday. Thinking I need to do a head gasket job. Never done one on a honda. Hope it isnt too difficult or expensive.
Am I right that the machine shop visit shouldnt be too much, and the rest is just a matter of unbolting stuf and putting the right gasket on when you re-bolt it. I am hoping I can do this all myself and keep this under a couple hundred,because I am not exactly flush with cash right now.
in my neck of the woods machine work isnt too much. less than $100 to resurface a head. as far as doing the actual labor, im sure that if you search on here you will find more than enough answers. also buy oem gaskets, I have had better luck with oem honda gaskets vs. aftermarket.
Rotating the tires. The Pirellis were getting kinda bald in front.
-matt
