Transfer case bearings
I think i have found a solution to all our bearing needs for the transfer case. If any of you are like me and you decided to rebuild your motor from the inside out, you may have ran into some problems with bearings like these.
or maybe this one that you just want to replace because you have replaced EVERYTHING else?
First, you're going to need a blow up of the transfer case and all of its guts...which i'll give you here.
the first bearing in the first photo is #19 in the blow up. you can see there are actually two of them inside there. The second photo has bearing #20 in the photo. There is a local bearing company here in the northwest called:
McGuire Bearing Company
http://www.mcguirebearing.com/
Located in:
Oregon: Portland, Salem, Eugene
Washington: Seattle, Tacoma, Spokane
Idaho: Boise, Idaho Falls
Utah: Salt Lake City
They are able to mic and measure both bearings and they can match them with a replacement.
Bearing #20 in the blow up:
Old on the right, new on the left
they measured out EXACTLY the same in every way. Bearing is sold in a pair with the bearing and sleeve together. #20 cost me $36.16 total and it was in stock on their shelf. i have NOT installed it yet and have NOT driven on it, but side by side they look perfect. I will be installing it tomorrow and i'll let you know how that goes and everything.
Just thought i'd put the info out there because all of these bearings are discontinued through honda.
Located in:
I found out that the part number is on the box.
320/28X
Turns out that Houston Bearing also carries the exact same item. The measurements should help out alot if you are unsure of the part.
Thanks for the info, 503Wagon
