Recommendations for bulbs - 1988 civic wagon
jolo100
Band Wagon
I have a 88 civic wagon, 5 door automatic.. And I am looking for some advice.
I would like to improve the lighting of the headlights and I was thinking of just replacing my current bulbs with new, better bulbs.
Thank you :smug:for your time and expertise...
Jon
- Cam I get better bulbs (low beam) in the front without getting a new kit.. Just bulbs?
- If I can get better lighting from replacing just the bulbs, can you please give me recommendations on appropriate bulbs?
Jon
So the bulb numbers have to do with the size of that bulb, not its strength?
I am 65 and driving at night can be tough as the light beam on the 88 civic is not the greatest.
About how long would either of the bulbs you recommended last? I have read all sorts of things like it's it possible that the voltage in my civic won't be able to handle the higher demand of either recommended bulbs and not only burn out fast, but mess up the alternator and electrical system? I don't know.
Thank you,
Jon
I gave seen the wattage vary, but I ordered 55 Watt bulbs, I saw some of the Silverstar Ultras with 80 watts.
Great top about not touching the bulb. Should I wear gloves or install the new bulbs with a cloth so I don't touch them?
Thank you,
Jon
